Date/Time: Mon, 06 May 2024 14:10:11 +0000
Excel Studies / Confluence / Symmetry
View Count: 1108
[2018-07-09 06:31:58] |
User371906 - Posts: 141 |
Hello, Is there a system or excel template to be able to use Excel option in Sierra Charts to find confluence or symmetry: Timing cycles Fibonacci Cluster levels Timing Clusters Comparing swings in the same direction with same number of days and price movement Thank you Regards g |
[2018-07-09 07:12:12] |
Really, this is best handled by ACSIL: Advanced Custom Study Interface and Language (ACSIL) Not Spreadsheets. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
