Date/Time: Sun, 05 May 2024 11:25:39 +0000
S&P 500 futures chart
View Count: 1827
[2018-07-08 02:09:18] |
Tom M - Posts: 5 |
I'm new here so this is probably a very basic question...thanks in advance for your patience. I'd like produce a basic bar chart of the activity in the September 2018 S&P 500 futures. I believe the symbol is SPU2018. When I enter this symbol directly I do not get any results and when I use the "symbol Find" feature I am not able to find it. Can you please let me know if am missing something? Thanks for your help with this. |
[2018-07-08 03:05:06] |
Tom M - Posts: 5 |
So I did some looking around and it appears as though the actual symbol is SPU18. That worked along with using the Intraday Chart option. Thanks |
[2018-07-08 07:49:20] |
The correct symbol is ESU18.
