Date/Time: Fri, 03 May 2024 09:16:14 +0000
Install version number not changing
View Count: 574
[2018-07-06 19:29:32] |
Willson - Posts: 176 |
I installed Current version (1778), but SC continues to show ver 1776 as the actual installed version. I expected the in-use version to change to 1778.
[2018-07-06 19:38:39] |
Make sure you select Help >> Download Prerelease when doing the update to get 1778.
