Date/Time: Sat, 04 May 2024 18:24:39 +0000
No TF Data for current contract month
View Count: 615
[2018-07-05 18:45:37] |
tfh6252 - Posts: 20 |
TF FMU0018!-NYBOT data has not loaded since the 6/7/18 Rollover. I've stepped through the appropriate Self-Help instructions and have verified no data is loading for this symbol. The Message log indicates RJU18 file is empty. My account is enabled for real-time TF data. Tom |
[2018-07-05 18:50:08] |
You need to use the RTY symbol instead. You can find this symbol in File >> Find Symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-05 18:50:31
