Date/Time: Sun, 05 May 2024 16:52:08 +0000
[Programming Help] - Gene
View Count: 822
[2018-07-05 14:24:36] |
User72965 - Posts: 114 |
On Live account ???? With Trade Window?? Will not put entry on my TPO Chart??? [visual ~~] Has Been Working ~~~~ Will put it on Sim 1 chart ??? Thx Gene :) |
[2018-07-05 18:19:45] |
Called I.B.They told me to try Mkt. And Limit orders. Mkt. went ok So did Limit. If Mkt went and Limit did not. Be a problem. So looks like they ok. Assuming on your end>!?!?!!? Oil get orders to show on Sierra chart. Not on I.B. Trader Work Station. ES Mini No show on Sierra Chart . Shows on Trader Work Station . ZB Bonds Shows on charts <> Not on Trader Work Station. Only thing I got from IB was to do with content .. i.e. decimals and how the orders are entered in on your end. I did down load 1776 latest version Sierra. Didn't help :( The Gene hope this helped .. |
[2018-07-05 18:53:10] |
No, none of this helps. This is all incomprehensible in general. And it is important to focus on one issue and only one issue and not confuse things. Tell us what you want to do and we will start from there. If you want to open a chart, let us know for what particular symbol. And only one symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-07-05 19:14:39] |
Was hoping you had a problem there. ~~~ It works on the Sierra Sim. Not on the Live. When I post an order (Live Acc't) on The Sierra Chart: Using Trade Window: It goes through to I.B and shows up On my Trader Work Station Platform. Not on the chart. Also if I cancel the order !!!!! I have to do it from I.B. Trader Work Station, It's not on the S. Chart ??? Also I have no Alert. "Order Has Been Cancelled" Alerts gone too???? I opened a new chart <> Same thing...... I'll send a chart ???? |
[2018-07-05 19:21:14] |
http://www.sierrachart.com/image.php?Image=1530818423470.png
[2018-07-05 19:23:09] |
lost today :( I count on this to trade. Much needed. Or lose tract of positions :( Gene thx |
[2018-07-05 19:29:18] |
http://www.sierrachart.com/image.php?Image=1530818921891.png
[2018-07-07 10:18:35] |
Resolved :) Was issue with IB a'cct. API needed changing . |
