Date/Time: Fri, 03 May 2024 12:39:11 +0000
TPO Chart - Open and Close Visualization
View Count: 860
[2018-07-05 11:14:48] |
User353585 - Posts: 66 |
Hello. With number bars, there are several options for open & close visualization. Candlestick Body Outline is the one I especially use because I can easily see what's inside the body range and what's inside the wick range. I hope to see the same functionality in TPO Profile chart although it is not a typical display of the TPO chart. Is there any workaround for now? like by using other overlaying study? Please let me know if there's something. Thank you. |
[2018-07-05 13:00:53] |
No, this is definitively not supported.
