Date/Time: Sun, 28 Apr 2024 00:03:20 +0000
Batch download of intraday OHLCV data
View Count: 1093
[2018-07-05 05:33:41] |
User27542 - Posts: 20 |
Hello, Is there a way I can download intraday (or daily) data for multiple symbols to a single folder on my hard drive in one go? Grateful for any help you can give. Thanks, TME246 |
[2018-07-05 10:48:41] |
Yes. Use the Associated Symbol List: Changing the Symbol of a Chart: Using the Associated Watch List Changing the Symbol of a Chart: Scanning (Method to do historical data downloads for Intraday charts) Changing the Symbol of a Chart: Downloading Historical Daily Data for Symbols List Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
