Date/Time: Mon, 06 May 2024 08:33:23 +0000
entry disappearing
View Count: 1013
[2018-07-04 14:38:25] |
User644540 - Posts: 7 |
I placed a trade on ZB and my entry price kept disappearing and reappearing. It was also showing I was never in the position on the trade and position tab. Once the entry appeared back on my chart I flattened the position and it reversed my entry.
[2018-07-04 19:23:09] |
Are you referring to the position line on the chart appearing and disappearing? The Positions tab of the Trade Orders and Positions window is reporting the information from Rithmic, in your case. Refer to: Trading Information Windows: Incorrectly Reported Trade Position Quantity So this sounds like some kind of Rithmic issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-04 19:23:28
[2018-07-05 14:58:18] |
yes,I was referring to the position line on the chart. Also Rithmic said they would be happy to accept an issue report from them if they can show it's a Rithmic issue. No other R|API platforms have reported similar issues.
[2018-07-05 15:41:22] |
There is no further help we can provide other than what was given in the prior post. It is up to you to determine if this was a Rithmic problem based upon what you saw and the information provided.
