Date/Time: Mon, 06 May 2024 17:40:52 +0000
Futures Broker provided Sierra Chart - can it also be used for Forex?
View Count: 554
[2018-07-04 11:16:22] |
User281933 - Posts: 4 |
Hi folks, I'm just trying to cover my bases here... I currently have Sierra Chart provided through AMP for futures trading (using CQG). If I get an LMAX Forex account, will I be able to configure Sierra Chart to also connect to LMAX as well? (So that I can trade futures through CQG and and also Forex through LMAX). Regards, Kieran |
[2018-07-04 19:21:33] |
For this you will need a direct account: Direct Sierra Chart Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
