Date/Time: Sun, 05 May 2024 18:44:50 +0000
[Programming Help] - toolbar button for Volume at Price Multiple
View Count: 1306
[2018-07-04 09:37:00] |
User37537 - Posts: 78 |
Hello, I was wondering if there is a way to create a toolbar button to control the Volume at Price multiple for a chart? When using a numbers bar chart with a volume profile background and scanning through equities, this setting needs to be manually changed often depending on the price and range of the displayed data for a stock in order for the profiles in the numbers bars to be visible. Instead of going to the chart menu every time, I would like to be able to add a toolbar button to quickly change the Vol at Price Mult to 1, and another one to change the multiple to say 10, for example.
[2018-07-04 09:45:09] |
Yes there is now. Since it is now possible to change study inputs using ACSIL. Refer to this function in studies2.cpp: scsf_ChangeStudyInputExample And refer to this page: Advanced Custom Study Interaction With Menus, Control Bar Buttons, Pointer Events Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-07 12:41:05] |
I have just recently had a chance to get back to this. I'm having trouble finding the api docuemntation for what I need. What I would like to do is create a toolbar button that when clicked, will perform the following: - Change the Volume at Price multiple on the chart to x - Change the 'ticks per volume bar' setting on a volume by price study on the chart to x Is this currently possible to do, if so can anyone provide an example on how to access / set these values? I'm an ACSIL noob but at least once I know how to access these settings I should be able to figure out the rest. Thank you! |
[2018-08-09 06:05:32] |
Refer to this function in studies2.cpp in the latest version of Sierra Chart: scsf_ChangeStudyInputExample The functions used in that example are currently documented. We have to add this capability: - Change the Volume at Price multiple on the chart to x
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-09 06:05:48
[2018-08-09 22:47:23] |
This will be supported in the next release: - Change the Volume at Price multiple on the chart to x
