Date/Time: Fri, 26 Apr 2024 09:37:23 +0000
Software Version
View Count: 2188
[2013-04-06 08:23:48] |
User14340 - Posts: 2 |
A great feature would be if software told you there was a new version available...
[2013-04-06 21:35:05] |
We do have this feature, but it is used infrequently. So you are not always notified every time there is a new version.
