Date/Time: Tue, 07 May 2024 15:29:34 +0000
Vol Above/Below last
View Count: 844
[2018-07-03 13:57:41] |
User645473 - Posts: 9 |
Hello, Following the image in attach, is it possible to move the Vol Above/Below Last from point 1 to 2 (chart Header)? This request is because if I scroll the chart down, I can't see that value. Many thanks |
Private File |
[2018-07-03 15:21:39] |
We can add an ability to put them at the bottom of the volume profile but there is no straightforward logical association to put it on the Chart Header. This has to do with the overall design the nature of those particular Volume by Price values and relationship to the chart bars. You can also view them in the Tool Values Window: https://www.sierrachart.com//index.php?page=doc/StudiesReference.php&ID=141&Name=Volume_by_Price#ViewingVolumeProfileTextInformation Which is really the recommended method in this case. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-03 15:21:59
