Date/Time: Thu, 02 May 2024 17:53:26 +0000
EminiMind.cht
View Count: 917
[2018-07-02 20:51:14] |
User24791 - Posts: 44 |
Hello, I have noticed each time Sierra Chart is updated to current version EminiMind.cht (2016 Update) gets automatically uploaded to platform which automatically opens. Under General Settings "Accept Server-Side Set Startup Files" Box is Unchecked. Can you please assist me in how do I adjust settings so this does not happen during each update. Thank You, David |
[2018-07-02 21:00:15] |
The automatic opening of this Chartbook is probably being done by the Transact software. See if you can find a setting for that within the Transact software.
