Date/Time: Fri, 03 May 2024 20:53:45 +0000
How to reset symbols included in symbol limit ?
View Count: 926
[2018-07-02 11:42:02] |
Acro - Posts: 436 |
Hi, I'm subscribing to futures and equities from the Sierra Real Time Feeds and have the 100 symbol limit. However, I've gone over the 35 limit for futures and indices and I am using three Sierra instances. Can you tell me how I get rid of some of those futures/indices so they don't count for the 35 limit as I want to change the ones I am monitoring real time. Thank You PS I've tried deleting some from my quote board but that doesn't seem to help me with the 35 limit Date Time Of Last Edit: 2018-07-02 11:43:02
[2018-07-02 14:20:01] |
Refer to: Chart Data and Chart Data Files: Reducing Number of Symbols Being Tracked by Sierra Chart Chart Data and Chart Data Files: Cleaning Up Old and Unused Symbols for Efficiency Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-07-03 05:17:06] |
Acro - Posts: 436 |
One final question on this. If you have activated both futures and equities exchanges but none of your equity charts or quoteboards are open at the moment, is your futures symbol limit still at the 35% threshhold or will it be at the 100%. Thanks |
[2018-07-03 06:43:03] |
is your futures symbol limit still at the 35% threshhold Yes.
