Date/Time: Sat, 27 Apr 2024 13:03:31 +0000
Blanks in Control bar not displayed
View Count: 625
[2018-06-30 22:58:05] |
nosast2 - Posts: 73 |
After upgrading to 1773 from 1768 my blanks between Control bar buttons are gone and it's not possible to add new blanks.. To group and align the buttons it would be nice to have blanks back. Thanks in advance |
[2018-07-01 08:19:38] |
We will look into this. That version uses a completely new control bar implementation which is much more efficient.
[2018-07-01 23:03:59] |
Still not fixed in 1774. Sticking with 1768 for the moment.
[2018-07-02 21:50:26] |
Fixed in 1776! thx |
