Date/Time: Sun, 05 May 2024 19:31:39 +0000
[User Discussion] - A SMALL CONTRIBUTION FOR SC USER COMMUNITY: COOL ICON FOR DESKTOP
View Count: 1332
[2018-06-30 21:30:31] |
Steve - Posts: 16 |
Here you are a new desktop icon that you can use if you wish ;) I am just hoping that SC team will also like it and put it into one of the new release ;) Save the attached .ico file on the same drive where your SC is (not on secondary drive if you use SSD so that you do not slow down app lunch by HDD) and a backup into your user folder. Do not rename it longer than it is or Windows will have issues with proper image size... Right mouse click on your default SC icon on your desktop and "change icon"... Than you can "pin it" to your WIn10 Start menu as well if you wish by RMB on the new icon and "pin it"... Date Time Of Last Edit: 2018-06-30 23:44:56
Capture.PNG / V - Attached On 2018-06-30 21:30:10 UTC - Size: 26.54 KB - 505 views SIERRA CHART.ico - Attached On 2018-06-30 21:39:44 UTC - Size: 16.6 KB - 1540 views |
