Date/Time: Fri, 03 May 2024 19:28:36 +0000
Real Time Data
View Count: 658
[2018-06-29 23:56:31] |
User171152 - Posts: 4 |
how would i know if i had real time data ? it seems my data is very delayed
[2018-06-30 08:15:56] |
Refer to the Real-Time Data page: Real-Time Data Most likely the data is delayed. It depends upon the symbol and services being used. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-30 17:18:55] |
so how do i get real time data .
[2018-06-30 19:23:10] |
What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on. If you require real-time futures data, then refer to: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php Be sure to read the page linked above, completely before you ask further questions about real-time futures data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-30 20:13:05] |
Futures crude oil and S&P 500. I’m new to trading and trying to work your software . Trying to practice charting in real time
[2018-06-30 20:18:09] |
Okay read this page from top to bottom: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-07-01 23:36:03] |
so basically i can purchase real time data for $5 for 2 week trial period then go from there after the trial period is over ?
[2018-07-02 06:33:01] |
Yes but you also have to consider exchange fees. There is no cost for the CME fees this month, but next month they can be very substantial.
