Date/Time: Sun, 05 May 2024 15:02:47 +0000
Replaying Multiple Symbols at the same time?
View Count: 736
[2018-06-29 22:43:09] |
User240019 - Posts: 112 |
HI, I have ES, CL & GC all in one chart book, just a simple volume based chart and and associated TPO using vwap for the bar chart. I'm trying to replay all three simultaneously, but it appears that the other charts (where the open is later than gold) do not play when their opening time frame hits. What can I do? |
[2018-06-30 22:13:12] |
Refer to these two sections: Replaying Charts: Automatic Skipping of Periods Where There Is No Trading and Synchronization https://www.sierrachart.com/index.php?page=doc/ReplayChart.html#ChartsToReplay Make sure you are replaying all the charts in the Chartbook. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-30 22:14:08
[2018-07-02 12:09:09] |
That was it! I needed to select "skip empty periods"
