Date/Time: Tue, 30 Apr 2024 22:31:29 +0000
Feature Request: Active Tab Display
View Count: 663
[2018-06-29 09:10:36] |
JanS - Posts: 46 |
Hi, While an active tab is usually colour-highlighted, this is not the case if the tab is linked and has a link colour applied to it. The only discernible difference is a slight border change. Please adjust this in a future version so that the active tab is clearly marked maybe with a strong border (the colour of which could be adjustable from within Global Settings) in addition to any link colour it may have. This was also addressed in Tab Display Thank you. |
[2018-06-30 08:19:14] |
We will see what we can do.
[2018-07-02 06:32:46] |
JanS - Posts: 46 |
Thank you very much for implementing this!
