Date/Time: Fri, 03 May 2024 13:19:15 +0000
CTS FIX connection
View Count: 1274
[2013-10-15 14:01:32] |
User14266 - Posts: 225 |
Lost connection 20 minutes ago and will not reconnect. CTS says the server is UP. There are a few people having problems at TsT. CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2013-10-15 08:58:26 Resolved address fix-sim.t4login.com to IP 69.44.110.196 | 2013-10-15 08:58:26 Error connecting socket. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-10-15 08:58:28 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2013-10-15 08:58:28 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-10-15 08:58:28 To prevent further connection attempts, select File >> Disconnect. | 2013-10-15 08:58:28 CTS FIX: Disconnected. | 2013-10-15 08:58:28 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-10-15 08:58:28 Date Time Of Last Edit: 2013-10-15 14:01:45
[2013-10-15 14:04:35] |
david18 - Posts: 2 |
same here
[2013-10-15 14:32:46] |
It's back up and running. CTS replied that they had a server issue on their end. They fixed it. All is well.
[2013-10-15 14:50:37] |
Thread reviewed.
