Date/Time: Wed, 08 May 2024 19:36:51 +0000
Background color
View Count: 507
[2018-06-27 14:53:25] |
User645473 - Posts: 9 |
Hello, Is it possible to set up a different color of the background every X ticks? In attach an example of what I'd like to do. Many thanks! |
Private File |
[2018-06-27 15:13:23] |
No, this is inherently difficult to implement. Do you require this? Perhaps it would be easier if we have a setting to use a different draw style for the horizontal lines every so many increments. That would be easier to do. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-27 15:30:38] |
I think the best way to do is to have a different draw style for horizontal lines every, for example, 5 points Thanks! |
[2018-06-27 15:36:08] |
Okay, we will work on this.
