Date/Time: Sun, 28 Apr 2024 00:20:56 +0000
Header of Charts not showing the pair name
View Count: 952
[2018-06-25 16:11:50] |
User954619 - Posts: 2 |
Hello, I downloaded the latest version of charts (version 1768) and now the header of each individual chart doesn't show the name of the pair anymore. I saved and closed GreenCharts, and also rebooted my computer. It is still not showing. Please help.
[2018-06-25 16:18:59] |
I erred: it's not the header of the chart that doesn't show, it's all the information on the thick title bar.
[2018-06-25 16:43:30] |
What do you see on the title bar of one particular chart? Is it completely blank. We are not observing any problems with this ourselves. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-25 16:43:39
[2018-06-25 17:37:49] |
Sawtooth - Posts: 3980 |
I have this same thing occurring in v1768, but only if I open a second chartbook, and then focus the first chartbook. Then the text in the Title Bar disappears on charts in both chartbooks. Date Time Of Last Edit: 2018-06-26 04:41:40
[2018-06-25 17:45:01] |
Okay that is interesting, we know what was done that apparently is related to this, but it is just an efficiency improvement, and it should not cause this problem . Also we do not notice this when having 2 Chartbook's open.
[2018-06-25 17:50:57] |
We can still not duplicate the problem but we implemented a solution which we think might help.
[2018-06-26 03:36:13] |
TechTrader - Posts: 116 |
This issue still occurs with prerelease SC1770 SC1763 does not have this issue. |
[2018-06-26 07:43:22] |
We have not yet done a new release.
[2018-07-04 07:38:03] |
samual sprat - Posts: 343 |
Same problem here - multiple chart books open and the title bar is blank on some charts in chartbooks. Running 1776. Has the update for this issue been released yet?
Date Time Of Last Edit: 2018-07-04 07:38:49
[2018-07-04 09:38:43] |
We are not sure why it happens and we cannot reproduce the problem. Anyway we thought of a solution, not really that efficient but will do it. This might be some sort of Windows 10 type of issue.
[2018-07-04 09:54:03] |
Problem still occurs on my system using Windows 7
[2018-07-04 10:20:34] |
Okay we understand the condition under which it occurs. It is when the option to Destroy Chart Windows When Hidden is enabled in the General Settings.
[2018-07-04 10:45:28] |
This is now resolved in prerelease 1777.
