Date/Time: Wed, 08 May 2024 02:21:10 +0000
API Keys
View Count: 592
[2018-06-25 16:07:51] |
Oleksandr Kryntsyglov - Posts: 1 |
Hello. I trade on the exchange Bitmex and I have 4 accounts through your program I can combine these accounts through the API keys?
[2018-06-25 17:19:13] |
What you can do is install four instances of Sierra Chart and set each one to use one of your BitMex accounts. One Sierra Chart instance for each BitMex account. Refer to: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
