Date/Time: Fri, 03 May 2024 17:20:15 +0000
DOM menu, Open Trade Window does nothing
View Count: 889
[2018-06-25 14:23:27] |
User759712 - Posts: 5 |
I am sim trading from the DOM. I like to have the associated Trade Window on another screen, not attached to the DOM. From the DOM, if I choose, Trade --> Open Trade Window for Chart, nothing appears. I can successfully attach the trade window, but when I uncheck the attach menu item, the trade window disappears (i.e., does not appear as a detached trade window anywhere on any monitor). I suspect it may have to do with copying my .cht files to my work machine. The DOMs were created on my home desktop where I have a very large screen and a 2nd monitor. At work, where this issue is occurring, I use a laptop with two normal- to small-sized monitors attached to the dock. My hunch is the Trade Window is somewhere off screen, and if that is true, do you have any ideas how I might find it and get it back onto one of the monitors? Thanks in advance, |
[2018-06-25 14:42:41] |
To solve this you need to select Chart >> Reset Child Windows. Refer to: Basic Trading and the Trade Window: Opening Trade Window for Chart or Trade DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
