Date/Time: Sat, 04 May 2024 21:43:18 +0000
[Programming Help] - STOP AND LIMIT ORDERS
View Count: 604
[2018-06-25 13:11:06] |
User82615 - Posts: 106 |
HELLO I'M STARTING TO PROGRAM MY OWN TRADING SYSTEMS USING ACSIL AND I HAVE A LITTLE PROBLEM , LET'S SEE IF YOU CAN HELP ME PLEASE: I'M TRYING TO CREATE A SYSTEM THAT ONCE I'M IN A POSITION IT WILL SEND AN STOP AND A LIMIT ORDER AT THE SAME TIME , AND THAT THESE ORDERS WILL UPDATE AT THE CLOSE OF EACH BAR. IS IT POSSIBLE TO PROGRAM THIS? DO I HAVE TO USE ATTACHED ORDERS ?. COULD YOU PLEASE GIVE ME A LITTLE ADVICE ON HOW TO PROGRAM IT? THANK YOU VERY MUCH IN ADVANCE FOR YOUR HELP |
[2018-06-25 14:54:24] |
We think the best thing for you to do is to use Attached Orders for the Target and Stop order: Attached Orders And then you can modify them as you need as explained here: Automated Trading From an Advanced Custom Study: Modifying an Order Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
