Date/Time: Tue, 07 May 2024 09:10:14 +0000
Number Bars issue Highlight min values not more working
View Count: 597
[2018-06-22 06:42:35] |
User657944 - Posts: 173 |
Hi Team, as per attached files you can see that the Highlight MIn Values is not working also if the settings are correct. Since two days ago it was working with some strange behaviour, I mean sometime one hourly candle was working fine sometimes not randomly but now it does not work at all. thx |
settings numbbars.png / V - Attached On 2018-06-22 06:42:19 UTC - Size: 59.68 KB - 262 views min not showed.png / V - Attached On 2018-06-22 06:42:28 UTC - Size: 138.4 KB - 240 views |
[2018-06-22 10:06:05] |
Update I saw that the chart stopped to show the min values afert 11.00 am EU time, I also open a new chart from zero and the results is the same. |
update min highlight.png / V - Attached On 2018-06-22 10:05:59 UTC - Size: 95.81 KB - 250 views |
[2018-06-22 14:31:00] |
Can You please look at my question? thx
[2018-06-22 15:11:39] |
I answer to my self and for anybody else that need to use it: it must not be set on automatic under the field Highlight Minimum Value In, but choose ask vol bid vol difference then it works probably in upgrading to the new release or for any other reason the system back to automatic.
