Date/Time: Sat, 04 May 2024 16:15:21 +0000
2 trading accounts same broker integration with sierra chart
View Count: 581
[2018-06-21 16:23:39] |
User450179 - Posts: 105 |
Hi, I have been trying to add a sub account with its own number to integrate with sierra chart. I cannot figure out how to do this under the data drop down menu on sierra chart. could you plese explain how this done? I looked at other support tickets etc but still did not see where or how to do this. I am running a second instance of sierra and it seems to be just referring back to the first instance and won't let me put anything into the boxes. Thank you JAY |
[2018-06-21 18:14:24] |
You need to have your broker assign the second account under the username for your trading account. This is not something that you can do from within Sierra Chart unless you are referring to simulated trading.
