Date/Time: Sun, 05 May 2024 01:15:56 +0000
VbP - Ticks per Volume Bar
View Count: 671
[2018-06-21 14:32:39] |
User645473 - Posts: 9 |
Hello, I'd like to set up 4 ticks per bar on my Volume by Price study. My question is about the price axys: as you see in the attached file, the range of 4 ticks (1 point of ES Futures) is ok, but it starts from 2754.50 to 2755.50. Is it possible to set up from 2754 to 2755, 2756, etc? Thank you!!! |
[2018-06-21 15:09:07] |
The way this works is that there is a standard method of rounding The following prices are rounded to 2755: 2754.5 2754.75 2755 2755.25 2755.5 actually is part of the 2756 volume level. This is how it works. So to change this I suppose would require that we add a rounding option. We would need to have rounding down, rounding up, or rounding to the nearest. Currently it is rounding to nearest. There is a fair amount of work to implement this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-21 15:10:08
