Date/Time: Mon, 09 Nov 2026 14:41:10 +0000
Single print at extreme study
View Count: 3745
[2018-06-20 18:02:05]
RIFT - Posts: 124
Can you please integrate number bars study the single print at extreme marker or create a new study? See the screenshot ...
Thank you very much!
Date Time Of Last Edit: 2018-06-20 18:02:34
imagesingle.print.at.extreme.png / V - Attached On 2018-06-20 18:02:28 UTC - Size: 245.79 KB - 1503 views
[2018-06-20 19:26:07]
binaryduke - Posts: 387
Available here:
https://www.emojitrading.com/indicators/single-print-at-extreme/
[2018-06-20 20:14:39]
John - SC Support - Posts: 48464
See if this option is what you are looking for:
https://www.sierrachart.com/index.php?page=doc/NumbersBars.php#Input_MarkNakedBidAskExtremes
[2018-06-20 20:59:42]
RIFT - Posts: 124
single print at extreme means:
1.) falling bar, last number top of the ASK is less than 10
2.) rising bar, last number down on the BID is less than 10
Can you make this marker please?
Thank you
[2018-06-21 05:01:23]
We will see about this.
