Date/Time: Mon, 29 Apr 2024 23:36:00 +0000
My DLL Causing 64 bit sierra crashing in beckest
View Count: 611
[2018-06-20 08:45:35] |
User30743 - Posts: 364 |
today it was the first time i backtested with 64 bit version and it kept crashing everytime i have two dll, one 32 bit (working fine with no problems) the other 64 bit (absolutely the same code - crashing everytime) it seems like it takes all the free HDD space and crashes afterwards. this is how it looks when i start backtesting in 64 dll (see the pict - 64 bit fail) after a couple of minutes this is what happens (see the pict - 64 bit fail 2) what is this suppose to mean that it eats all my hdd space? it frees it up after i close the sierra chart. the backest is of course not finished.. i am testing one minute chart (500 days back) so this is something that should work i guess.. can you explain? Date Time Of Last Edit: 2018-06-20 08:46:56
64 bit fail.png / V - Attached On 2018-06-20 08:45:24 UTC - Size: 40.85 KB - 228 views 64 bit fail 2.png / V - Attached On 2018-06-20 08:45:28 UTC - Size: 160.25 KB - 231 views |
[2018-06-20 11:20:16] |
You tell us what the problem is. It your study. Refer to: Sierra Chart Unexpectedly Shutting Down | Memory Errors | Unusual Software Problems | Exception Errors | Freezing of User Interface Sierra Chart does not use files for custom studies processing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-20 12:30:22
[2018-06-20 18:28:56] |
well i dont know, maybe it was because i did not have freedll 0. with freedll 0 this doesnt happen. but it is strange anyway.. it ate all my hdd space and 32 bit did not do it even though it had freedll 1 too |
