Date/Time: Mon, 29 Apr 2024 02:37:13 +0000
DOM Setup for Trailing Stops
View Count: 1043
[2018-06-20 04:03:04] |
andrew miles - Posts: 21 |
I would like to set up the folllowing. At 8 ticks profit move stop to BE+1 After 11 ticks profit i would like the trail to follow the market by 6 ticks. I have searched the web but no videos on setting up trails with sierra and after trying to set this up i just cannot get anything like it. Can you tell me what i have to do rather than referring me to the documentation which i have tried to use with no avail |
[2018-06-21 16:19:33] |
Refer to: http://www.sierrachart.com/index.php?page=doc/TradeWindow.html#ConfigurationFileAnotherSource The Trade Window configuration file is attached. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-21 16:25:06
UserTradeWindowConfig_2018-06-21.twconfig - Attached On 2018-06-21 16:18:56 UTC - Size: 6.52 KB - 246 views |
[2018-06-22 01:44:24] |
Excellent. Thank you very much. I have one issue with my DOM. The Reverse is simply not working. I checked in global settings and its clearly visible but it just does not work. So the cancel button has a grey area around it until you put an order in and the reverse should activate once in a trade but mine does not. IS there another setting for this as it used to work. Thank you
[2018-06-22 14:30:02] |
Make sure it is not disabled through Global Settings >> Chart Trade Settings. Refer to: Global Trade Settings Windows: Chart Trade Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
