Date/Time: Thu, 02 May 2024 17:37:53 +0000
Signal Only On Bar Close
View Count: 1871
[2018-06-19 16:40:23] |
User513228 - Posts: 41 |
Hi, On my spreadsheet trading system i seted up option "Signal Only On Bar Close" to " YES " on both sides. So when i using 30m chart i should recieved signal only every 17:00,17:30,18:00 etc. I dont know why last day i start recieving signals on random time like 17:22, 18:12 etc. I dont know where is problem. I nothing changed. When i run backtest of my strategy from last 40 days. Every 68 orders is fine, max 1 minute different. But from yeasterday 18.06.2018 i recieved 3 signals with wrong time. Where can be problem ? |
problem.png / V - Attached On 2018-06-19 16:36:48 UTC - Size: 135.42 KB - 341 views |
[2018-06-22 14:04:31] |
bump
[2018-06-22 14:16:12] |
Make sure you have the Replay Mode set to Accurate Trading System Back Test Mode: https://www.sierrachart.com/index.php?page=doc/ReplayChart.html#ReplayMode Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-23 23:56:41] |
Im sure. But that´s not just replay thing. Im gettin signal on random time on Live Trading too. Few minutes ago my trading serivce got signal and opened trade on 1:45am
Date Time Of Last Edit: 2018-06-24 00:04:34
[2018-06-23 23:58:54] |
For live trading make sure your computer clock is set accurately. Refer to help topic 38: Incorrect Date and/or Time Display, Missing Historical Intraday Data, Chart Not Updating Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-24 00:25:36] |
My time is OK. It makes no sense to me. Why results from last 2 month are okey and just from last days are wrong ? That cant be because i have clock issues.
[2018-06-24 10:21:51] |
We are going to be doing some testing and determine what the issue is.
[2018-06-27 14:03:41] |
We have been unable to reproduce this, but the particular order fill date-time that you see should be near the beginning of the very next bar. Being these are 30 minute bars, you should see a date-time at least 30 minutes into the future as compared to the starting date-time of the bar being evaluated. We are seeing earlier than that and we are not sure why. The only thing we can think of at this time to suggest is to use the very latest prerelease which we are currently testing on. Or it could be some sort of data time stamping issue. So the problem could be with the underlying data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-27 14:05:14
[2018-07-02 18:42:58] |
Few days after i created this topic was okay again. But few minutes ago did it again and i get signal in NON-SIMULATED mode. Now i tried install latest version, run backtest but this order is still there. Check attachment. BTW im using RENKO Chart. Maybe is problem there
Date Time Of Last Edit: 2018-07-02 18:48:22
[2018-07-02 18:53:05] |
My Renko chart config in attachment. Last two months was okay. Problems stared when i created this topic
Screenshot_8.png / V - Attached On 2018-07-02 18:52:32 UTC - Size: 34.38 KB - 308 views |
[2018-07-02 19:39:09] |
Okay now we understand the problem. We are declining support for this. Do not use the Renko study. We provide no support for that whatsoever and we are going to need to remove it. Use the Renko bars as documented here: Renko Bar Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-07-02 21:19:03] |
Okay but how can i get same results as when im using Renko Chart study ? Where i can set up Box Size to 2 and "Use High/Low Values instead of Last Value" condition ? Sorry im not tech guy, i just made strategy and get best results with this settings so i need made same settings in "Chart Settings". Thanks
Date Time Of Last Edit: 2018-07-02 21:23:24
[2018-07-02 22:33:11] |
The Renko bar size is specified in ticks and it uses all of the data. So the high and low values will be used. You just need to follow through the instructions here: Renko Bar Charts: Using Renko Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-07-10 13:21:40] |
Only in the latest pre-release and that is explained here: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer1778 Not in the version you are running. We need more information about the issue you are having in order to understand it. What exactly do you mean by "stopped works". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-07-10 13:45:51] |
It´s working now i found problem. I tried prerelease version and yes, it´s not working there. I tried Renko at Chart Setting but i cant get same results as when im using Study. It´s possible or im doing something wrong ?
Date Time Of Last Edit: 2018-07-10 13:47:56
[2018-07-10 14:11:29] |
Well there certainly is going to be a difference in the results with using the true Renko bars in the Chart Settings. That does not mean you are doing anything wrong.
[2018-07-10 16:15:34] |
Yeah but i have much better results with Renko Study. So i can using this after updates right ?
Date Time Of Last Edit: 2018-07-10 16:16:15
[2018-07-10 16:55:45] |
To continue to use the Renko studies, just follow the instructions here after updating to 1778 or higher: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer1778 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-10 16:56:00
