Date/Time: Sun, 28 Apr 2024 23:13:03 +0000
error message
View Count: 541
[2018-06-19 15:41:26] |
Glenn Infinity - Posts: 103 |
Hi, one of my customer's was using Emoji trading chartbooks on a trial basis. and is now getting the below error message he has removed anything referencing "ETOF" or "DeltaScalper" from the data folder in the C: drive but the error persists, do you have any suggestions. He also says the study is not on any of the chartbooks he is using Warning: The Custom DLL study “ETOFSv2.0scsf_DeltaScalper” has just caused a CPU exception.\2018-6-18 11:15:53 Warning: The Custom DLL study may cause AT to be unstable until you remove it from your chart and restart AT.\11:15:53* |
[2018-06-19 15:53:27] |
They really need to go through all of the charts within the open Chartbook's and make sure there are no studies from ETOFSv2.0. You can find all of the open charts through Windows and Chartbook: Window and CW Menus: Windows and Chartbooks (Window) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-19 16:04:05] |
Thank you!
