Date/Time: Fri, 03 May 2024 20:45:33 +0000
[User Discussion] - AUDIO ALERT
View Count: 507
[2018-06-19 11:17:01] |
User635423 - Posts: 51 |
Is it possible to get an audio alert after the close of every Price Bar if so how can I set this up? I am using the following chart settings. 1. “Range per Bar – Standard (7 ticks)”. 2. Reversal Bars (5-0) Thanks, |
[2018-06-19 13:05:02] |
You can do this by using the Countdown Timer study. Refer to the documentation for that particular study.
