Date/Time: Fri, 03 May 2024 03:07:12 +0000
Trial
View Count: 521
[2018-06-18 18:52:08] |
mosheikh - Posts: 5 |
Thank you. However, I'm currently now having a problem with historical data not downloading. I get the error message: "HD Request # 13 | Error downloading historical Intraday data for XBTUSD-BMEX. The network socket has been closed. Retrying download. | 2018-06-18 18:23:42" Is there any way for me to fix this? Currently only data from when I initially connected "10 minutes ago" is displaying on the charts, changing settings only results in the above message. No historical bars are showing at all. Thank you. |
[2018-06-19 00:30:02] |
Refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Error when Downloading Historical Intraday Data from the Sierra Chart Historical Data Server You also had two other posts in regards to this and those have been deleted because they are the same problem as this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-19 00:31:18
