Date/Time: Sat, 04 May 2024 10:56:18 +0000
Chart resets a study data
View Count: 557
[2018-06-18 15:22:18] |
chart_warrior - Posts: 96 |
I have a study added to my chart "Bid and Ask Bars" to show a ratio, depth, etc. Any time I add something new to the chart everything gets reset and I loose daily graph. Is there any way to record this data so it doesn't get reset? See region 2 on the screenshot, most of it is blank because I added a horizontal line and clicked Apply. |
2018-06-18_11-19-32.jpg / V - Attached On 2018-06-18 15:22:03 UTC - Size: 150.76 KB - 251 views |
[2018-06-18 23:55:34] |
This is explained here in the documentation for the study: Bid & Ask Depth Bars You need to use the historical market depth data instead. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
