Date/Time: Fri, 03 May 2024 08:36:52 +0000
DOM> how to increase price column
View Count: 1606
[2018-06-18 15:11:23] |
User774117 - Posts: 7 |
Dear Sierra Tech Support, I have found the command to increase the Bid/Ask font size column. But I can’t find an intuitive way to increase the font size of the column with the price. Attached is a screenshot. Please clarify. Thank you. Best Regards Cheryl |
Font setting for central Price column 2018-06-18_17-03-18.jpg / V - Attached On 2018-06-18 15:08:26 UTC - Size: 179.85 KB - 326 views |
[2018-06-18 23:48:17] |
The font for the Price is controlled with the Chart Text setting on the Graphics Settings page. You will find the documentation for this item here: Graphics Settings: Fonts and Text Appearance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-02-19 15:09:24] |
Dear Sierra Tech Support, Related to the DOM settings, I can only find the DOM Quantities/Sizes - (current font name) This changes the font properties for DOM Quantities and Sizes. But I can’t find an intuitive way to increase the font size of the price on DOM. Could you please clarify? Thank you. Date Time Of Last Edit: 2019-02-19 15:13:03
[2019-02-20 00:59:19] |
Do you mean all of the prices in the price column on the Chart/Trading DOM?
[2019-02-25 18:42:58] |
That's correct; the font size of central column of the ladder (i.e. between the Bidsize /Asksize).
[2019-02-25 19:19:06] |
This is controlled by the Chart Text font: Graphics Settings: Fonts and Text Appearance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-03-04 23:24:50] |
Thank you but unfortunately at the DOM settings at Graphics Settings: Fonts and Text Appearance I can only find the DOM Quantities/Sizes - (current font name) This changes the font properties for DOM Quantities and Sizes. But I can’t find the specific command to increase the font size of the price on DOM. Could you please clarify? Thank you. |
[2019-03-05 02:31:01] |
You need to change the font for "Chart Text" . This is what we said in our prior post.
