Date/Time: Sun, 19 May 2024 00:37:40 +0000
DOM with BUY/SELLSTOP using mouse left-click & Ctrl key
View Count: 2141
[2018-06-18 14:30:23] |
User774117 - Posts: 7 |
Dear Sierra Tech Support, Is there a way to place a buy/sell stop order on DOM by the way of a mouse left-click & pressing the Ctrl key? I used to trade that way... I cannot find that configuration at http://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#ChartDOMSettings Thank you. Kind regards, Cheryl |
BUYSTOP Left click & ctrl 2018-06-18_16-21-30.jpg / V - Attached On 2018-06-18 14:29:31 UTC - Size: 168.79 KB - 484 views |
[2018-06-18 23:56:57] |
No, this can only be done with left or right clicks only in the buy and sell columns. You can set the order type configuration through these settings: http://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#ChartDOMSettings Or you can use the chart shortcut menu supported by Chart Trading: Chart Trading and the Chart DOM: Entering Orders From the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-18 23:58:13
[2019-02-19 15:03:30] |
Dear Sierra Tech Support, Did you change something about this topic in the last 6 months? I would like to be able to place a buy/sell stop order on DOM by the way of a mouse left-click & pressing the Ctrl key, so adding the keyboard as input of the combination, not simply assigning a kind of order to left/right clicks. Thank you. |
[2019-03-12 15:15:08] |
Dear Sierra Tech Support, Is it possible to fill a request for feature implementation, please? |
[2019-03-14 20:49:23] |
There definitely is no chance Sierra Chart will support this.
[2020-08-14 06:22:37] |
beanthehacker - Posts: 28 |
I would also be a user of this feature. Thoughts behind: Users don't want simple mouse clicks to enter an order directly since clicking by mistake is very common. But when used with Ctrl or shift buttons we can know we are consciously entering an order and no further confirmation is needed. Click + pop up asking for confirmation is pretty slow and not helping. An auto-send feature for Ctrl/Shit + mouse clicks is what we are asking for. Thank you!
[2020-08-18 12:33:40] |
Have a look at this functionality: Chart Settings: Extend Chart DOM Across Entire Chart When Using Ctrl(Buy) / Shift(Sell) (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
