Date/Time: Fri, 03 May 2024 04:31:49 +0000
ACSIL Triggered trailstop
View Count: 1533
[2018-06-17 09:57:19] |
@sstfrederik - Posts: 403 |
Hi, Can an adjustment be made to set s_SCNewOrder::TriggeredTrailStopTriggerPriceOffset and s_SCNewOrder::TriggeredTrailStopTrailPriceOffset separately for each OCO Group? Thanks, Frederik |
[2018-06-20 17:05:56] |
Hi SC engineers, Is this under consideration? Thanks, Frederik |
[2018-06-21 06:01:18] |
No it is not. It is not something we can do now.
[2018-06-21 10:06:38] |
We thought of a way this can be done with too much complication by using separate structure members individually for the different OCO groups and keeping the existing members. We will see about adding those.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-21 10:35:47
[2018-06-24 08:54:59] |
Thanks for working on this. Any timeline you can share?
[2018-07-04 14:41:37] |
Hi SC engineering, I am working on a new release of my Autotrading study and would like to implement the separate triggered trailing stop for each OCO group. Would be great to have an estimate on when this can be added. This will help in my decision to add a work around to my study or wait for this addition. Thanks in advance. Frederik simplesystemtrading.com New autotrading study released |
[2018-07-06 12:55:59] |
We should be able to get to it within the next 10 days.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-06 12:56:23
[2018-07-13 17:45:31] |
These will be added to version 1782: double s_SCNewOrder::AttachedOrderStop1_TriggeredTrailStopTriggerPriceOffset; double s_SCNewOrder::AttachedOrderStop1_TriggeredTrailStopTrailPriceOffset; double s_SCNewOrder::AttachedOrderStop2_TriggeredTrailStopTriggerPriceOffset; double s_SCNewOrder::AttachedOrderStop2_TriggeredTrailStopTrailPriceOffset; double s_SCNewOrder::AttachedOrderStop3_TriggeredTrailStopTriggerPriceOffset; double s_SCNewOrder::AttachedOrderStop3_TriggeredTrailStopTrailPriceOffset; double s_SCNewOrder::AttachedOrderStop4_TriggeredTrailStopTriggerPriceOffset; double s_SCNewOrder::AttachedOrderStop4_TriggeredTrailStopTrailPriceOffset; double s_SCNewOrder::AttachedOrderStop5_TriggeredTrailStopTriggerPriceOffset; double s_SCNewOrder::AttachedOrderStop5_TriggeredTrailStopTrailPriceOffset; In the case of a triggered trail stop order, when the above variables are not set, the original variables will be used instead. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-13 17:46:29
