Date/Time: Fri, 03 May 2024 03:53:22 +0000
Add Aditional Symbol stops working with more than 5 symbols
View Count: 938
[2018-06-15 17:03:28] |
Cavalry3162 - Posts: 523 |
hello SC, after adding a 6th symbol to a chart none of the added symbols update anymore... screenshot of my chart added, that "downloading" for the gold symbol just didnt update, it already had downloaded all the date. please advise.. thanks, Andreas |
2018-06-15_11-12-47.jpg / V - Attached On 2018-06-15 17:03:13 UTC - Size: 134.33 KB - 262 views |
[2018-06-15 18:15:20] |
Disregard the prior response. Actually, we do see that if one symbol is in a downloading state, none of the Add Additional Symbol studies will update. Not sure why we do it that way, so we need to look into this some more. If the download actually completed for that symbol and the state is still showing as downloading, not sure at this point why would that be the case, but update to the current version. At this point do not post further about this so we have a chance to look into this, unless the issue is resolved. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-16 01:09:52
[2018-06-21 05:11:16] |
We have updated the documentation in regards to this. Add Additional Symbol: Updating of Additional Symbols in Chart We have added a backup method in the latest release to detect the completion of a historical data download for the Add Additional Symbol study. This is not the perfect method because it will not cause a reload of the chart if necessary, but it does serve as a backup method of detection. We really do not see why there would be a problem to begin with though. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
