Date/Time: Fri, 03 May 2024 04:59:09 +0000
Relative Volume Study - Bug?
View Count: 792
[2018-06-14 23:07:29] |
codytrades85 - Posts: 7 |
Hello, I've used the elusive search button to read the support board, and read a few posts about the Relative Volume study, but didn't find any answers. On this page: Relative Volume It states: "The Cumulative Volume Ratio is displayed using the Calculative Volume Ratio Subgraph. If you only want to display this one Subgraph and not the Relative Volume, then set the Relative Volume Subgraph Draw Style to Ignore." The problem is, when I change Draw Style from Bar to Ignore on Relative Volume (SG1) and hit Apply or OK it immediately switches back to Bar. After reading the forum posts, I noticed that this study was under development recently so I just downloaded and installed the latest version 1762 to see if this had already been addressed, but it looks like the bug is still there. I attempted a workaround by creating my own custom study by copying the code from studies8 and modifying the default setting for RelativeVolume.DrawStyle but get a build error C3861: 'MovingMedian_S': identifier not found Thanks for your time. |
[2018-06-15 02:01:36] |
The correct name of the subgraph is Cumulative Volume Ratio and the documentation has been corrected. The problem is, when I change Draw Style from Bar to Ignore on Relative Volume (SG1) and hit Apply or OK it immediately switches back to Bar. 'MovingMedian_S' is located in the SCStudyFunctions.cpp file. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-15 15:39:17] |
John - SC Support - Posts: 31334 |
We have fixed the bug where it was forcing the Draw Styles for some of the subgraphs. This will be in the next release (1766). It will probably be a day or two before it is released, but look for it to be posted on the Main Sierra Chart webpage ( https://www.sierrachart.com/ ) in the upper right corner. Once available, you can download the latest Pre-Release by following the instructions here: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-20 04:19:39
