Date/Time: Sun, 19 May 2024 02:18:27 +0000
Price display format and tick size
View Count: 1318
[2018-06-14 20:56:22] |
JamesP - Posts: 89 |
What is the best way to ensure I'm using the correct price display format and tick size when testing an unfamiliar product. For example what is the price display format and tick size for the Eurodollar(GE)? If I check off Auto-set from data feed will this ensure I have the right price display and tick size? I'm using sierra chart data feed. Thanks in advance.
[2018-06-14 21:14:24] |
We recommend that you do not enable Auto Set from Data Feed. It is best to keep it disabled. In the case of Eurodollar futures, the tick size and price display format will already be correct already. However, if you need to manually change them you can: Chart Settings: Tick Size (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-14 21:14:39
