Date/Time: Mon, 06 May 2024 08:32:27 +0000
Rithmic fee
View Count: 509
[2018-06-14 15:35:17] |
User25311 - Posts: 30 |
Hi, I'm going to setup muy Sierrachart for trading with Rithmic. But they said me that there is an API fee when trading with SC in certain cases ($20/Monty). I would like to know if there is any possibility for avoiding this fee? Is there any other connection type instead through API? Date Time Of Last Edit: 2018-06-14 19:29:52
[2018-06-14 19:29:22] |
You cannot avoid that Rithmic fee. You could look at using other supported services. They are all listed here: Supported Data and Trading Services: Supported Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
