Date/Time: Tue, 07 May 2024 23:40:53 +0000
Exporting data tick by tick data to Excel
View Count: 1775
[2018-06-14 03:56:34] |
User665108 - Posts: 11 |
Exporting data tick by tick data to Excel , can you please let me know how you can export tick by tick data to Excel. I was Trying to see how I can export tick by tick data to excel spreadsheet , thank you |
[2018-06-14 05:17:13] |
Follow the instructions here: Exporting and Importing Intraday Data Files: Export and Edit The export is not to Excel, but to a text file which you can then open in Excel. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-14 05:17:56
