Date/Time: Sun, 19 May 2024 01:11:03 +0000
Replay Hangs After Pause/Play
View Count: 727
[2018-06-13 16:05:14] |
Alberto Gauer - Posts: 121 |
Would like to know why the Market replay hangs if we click "pause" and go for lunch or something, then when you come back you click "play" and nothing happens, all is still.
[2018-06-13 16:34:19] |
So the "fix" I´ve found for that was skipping the time forward or backwards, then it makes the sim to start again. But still, if you pause the sim for a longer period of time, when you press play it hangs.
[2018-06-14 03:40:33] |
We cannot reproduce this problem and we see no technical reason for it after reviewing the code. Make sure you are running the current version of Sierra Chart: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-14 10:52:02] |
Hi guys. Ok. Yeah for me is standard procedure to check for current versions after launching sierra. Have you tried to run a sim and leave it paused for 1h, 2h, and then press play? Try with a chartbook containing 16 charts and different complex studies, studies referencing one another in different charts, etc... |
[2018-06-14 12:31:55] |
Hey guys I´m sorry you are correct. I didn´t pay attention to the date, dumb moment. It was hanging because it was a friday duh. |
