Date/Time: Sat, 04 May 2024 23:14:58 +0000
Arrow tool text anchor changed in 64bit version
View Count: 903
[2018-06-13 13:05:57] |
aknsyu71@gmail - Posts: 49 |
Hi, The arrow tool's text anchor used to be at the start end of the arrow and since I updated to the 64bit version, the text is at the arrow end of the arrow tool. Is this intentionally changed? Will there be a choice for this sometime in the future, which end of the arrow line anchors the text? Many thanks |
[2018-06-13 19:11:39] |
We will look into this.
[2018-06-24 11:22:41] |
User37537 - Posts: 78 |
Hello, I am also curious about this. Although I am still on x86 version the arrow text appears at the end with the arrow head. I just tried using this feature for the first time so I'm not sure what it used to do but having the text on the arrow head end is not really useful for me.
[2018-06-24 18:25:27] |
We apologize for the delay. We will get this done. There is going to be a new option added to control the text placement.
[2018-06-26 21:27:43] |
John - SC Support - Posts: 31362 |
We have created a new option on the Line, Chart Calculator, ZigZag, and Arrow Configuration/Properties page that states Draw Text At End. By default, the text will display at the first entered point like it used to do. Selecting this option will move the text to the other end (or the second entered point). Look for this update in the next release (1771). It is typically a day or two for the next release. You will find the information on the releases on the main Sierra Chart website on the top right of the page. When available, you can perform a fast update by following these instructions: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
