Date/Time: Sun, 19 May 2024 13:52:09 +0000
Amp brokerage in combination with LMAX
View Count: 1220
[2018-06-12 17:20:31] |
grantx - Posts: 244 |
If I sign up and trade futures through Amp brokerage, the deal is I can get service package 3 for free. Will I be able to use Sierra Charts with LMAX even though Ill be getting it for free with Amp? |
[2018-06-12 19:03:56] |
We have to check but there is no assurance you can use LMAX.
[2018-06-13 07:17:44] |
Did you find out?
[2018-06-13 09:58:31] |
ElmStreetTrader - Posts: 48 |
More than likely not. When I had an Amp-provided account the only data services I could log on to were CQG, CTS and Rithmic so for FXCM (similar setup to LMAX) I had to use my direct account.
[2018-06-13 10:42:35] |
Thanks ElmStreetTrader. Amp has some pretty cheap pricing for futures data...only $5 per month for currencies and the sierra platform for free.
[2018-06-13 19:16:07] |
You need a direct account to use LMAX: Direct Sierra Chart Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
