Date/Time: Sun, 19 May 2024 16:25:51 +0000
Rithmic child orders: not sent to server?
View Count: 759
[2018-06-12 13:26:41] |
phaedonk - Posts: 352 |
I see that child orders are kept locally and are "live" only when the parent is filled. I do not see a setting to change that.
[2018-06-12 14:02:21] |
Xfanman1 - Posts: 320 |
Global Settings/General Trade Settings Check the boxes you want on the right side of the window (see attached image). If Rithmic supports Server Side bracket orders (and as long as you don't have Scaling turned on) you should be all set. -- Scott |
ServerSideOrders.PNG / V - Attached On 2018-06-12 14:01:22 UTC - Size: 71 KB - 242 views |
[2018-06-12 14:27:33] |
Thanks for the suggestion. However, Rithmic supports them and the option was already enabled so I'm not sure what I need to do.
[2018-06-12 16:00:27] |
Oops. Missed this: Server Managed Bracket Orders: No. However, once parent order fills, OCO bracket is server managed. However: Server Managed OCO (Order Cancels Order): Yes. Global Settings >> Global Trade Settings >> Use Server-side OCO needs to be enabled for server-side OCO support. So, this is a little confusing, but I guess I'm out of luck. SC, this means that the computer needs to always be online before the server takes over and manages the trade after the fill, correct? Date Time Of Last Edit: 2018-06-12 16:00:57
