Date/Time: Sun, 19 May 2024 21:02:02 +0000
Missing trades in the activity log
View Count: 1110
[2018-06-12 13:25:49] |
tarik medjber - Posts: 13 |
Hi, I recently started using sierra and made my first trade, closed out and and tried to see it in the activity log but the only evidence of the trade was on the 'trade stats for charts' section.. I cannot see it on any other section of the log?
[2018-06-12 18:03:28] |
Refer to this section here about this: Trade Activity Log: Missing Order Fills from Trade Activity Log The first thing to look at is the filtering options in the top of the Trade Activity Log window. Make sure that the other filtering options in the top of the page, are not set to something that might not show you the particular trade you are looking for. Refer to the documentation here regarding those filtering options: Trade Activity Log: Controls Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-12 18:11:15] |
I figured it out. I changed the symbol list to non-simulated. Worked straight away after that. Thanks!
