Date/Time: Sun, 19 May 2024 15:32:57 +0000
VolumeAtPriceThresholdAlertV2 why use it all AVAILABLE Subgraphs?
View Count: 706
[2018-06-11 22:28:11] |
TedMar - Posts: 189 |
Hi, im not undersatnd why is all Subgraphs use needed ? What is the reson? Example: Studie8.cpp scsf_VolumeAtPriceThresholdAlertV2 if (sc.SetDefaults) ..... ..... for (int SubgraphIndex = 0; SubgraphIndex < SC_SUBGRAPHS_AVAILABLE - 13; ++SubgraphIndex) { SCString SubgraphName; SubgraphName.Format("Trigger %d", SubgraphIndex); sc.Subgraph[SubgraphIndex].Name = SubgraphName; sc.Subgraph[SubgraphIndex].PrimaryColor = RGB(255, 128, 0); sc.Subgraph[SubgraphIndex].DrawStyle = DRAWSTYLE_SQUARE_OFFSET_LEFT_FOR_CANDLESTICK; sc.Subgraph[SubgraphIndex].LineWidth = 8; sc.Subgraph[SubgraphIndex].DrawZeros = 0; sc.Subgraph[SubgraphIndex].DisplayNameValueInWindowsFlags = 0; } in fact when a Bar have more as 60 Price Levels with ThresholdAlert (true) , then all Allerts over 60 Subgraphs no displayed on BAR. I tryed output over one graph only , but i get only 1 Price level alert. |
[2018-06-12 00:15:50] |
A study subgraph can only draw one line/object at each chart bar. So if we want to highlight multiple price levels where the condition is true, we need to use a separate subgraph for each price level.
[2018-06-12 06:39:24] |
Any way or idea to resize Subgraph Array ?
[2018-06-12 18:31:23] |
The resizing of a Study Subgraph array, when it comes to the number of elements timewise along the horizontal axis, is automatically resized as needed to match the main price bars. Also refer to: ACSIL Interface Members - Variables and Arrays: sc.IsCustomChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-12 18:31:42
